Knowledge Base Article
Warning: Port "datab" on the entity instantiation of "lpm_add_sub_component" is connected to a signal of width 32. The formal width of the signal in the module is 16. The extra bits will be ignored.
Description
You will see this warning, perhaps multiple times, when you create simulation models for an NCO II Intel® FPGA IP.  You might also see the following warning message:
Warning: Verilog HDL or VHDL warning at nco_altera_nco_ii_140_riojqbq.v(91): object "select_s" assigned a value but never read
Resolution
These warnings can be safely ignored, they will cause no simulation problems and do not affect the synthesis models.
Updated 16 days ago
Version 2.0
