Knowledge Base Article
Warning: PLL cross checking found inconsistent PLL clock settings.
Description
The Quartus® II software version 9.1 SP1 and later may generate the following warnings, when a transceiver PCS is used in designs targeting Stratix® IV devices:
Warning: PLL cross checking found inconsistent PLL clock settings:
Warning: Clock: <instance name>|receive_pcs0|clkout does not match the master clock period requirement: 0.001
Warning: Clock: <instance name>|transmit_pcs0|clkout does not match the matser clock period requirement: 0.001
These warnings on transmit and receive PCS clock outputs can safely be ignored because the clock period for these clocks is automatically set correctly in the TimeQuest Timing Analyzer.
This problem is currently scheduled to be fixed in a future version of the Quartus II software.
Updated 1 month ago
