Knowledge Base Article
Warning: Overwriting existing clock: <clock name>
Description
This behavior may been seen in Quartus® II software version 10.0 when your design has either of the following two MegaCore® functions:
- QDR II and QDR II SRAM Controller with UniPHY v10.0
- RLDRAM II Controller with UniPHY v10.0
The warnings occur because all project Synopsys Design Constraint (.sdc) files are reread when the Report DDR task is executed in the TimeQuest Timing Analyzer.
To work around this problem, modify the <variation_name>_report_timing.tcl with the following steps:
- Locate the following line:
if { ![string match *GUI*DDR* [get_current_timequest_report_folder]] } { - Replace the line with the following two lines:
set signoff_mode $::quartus(ipc_mode)
if { ![string match *GUI*DDR* [get_current_timequest_report_folder]] && !} {
This problem is scheduled to be fixed in a future version of the Quartus II software.
Updated 1 month ago
