Knowledge Base Article
Warning: OUTCLK port on the PLL is not properly connected on <instance>. The output clock port on the PLL must be connected. Info: Must be connected
Description
When you compile the Triple Speed Ethernet (TSE) IP in LVDS mode for Arria® V devices, you will get the following warning messages during Analysis & Synthesis:
Resolution
The reason for this warning is due to ALTLVDS_RX generating a slow PLL clock even though it is in soft-CDR mode and only the DPA clock is being used.
The warning simply indicates that the slow clock PLL has no fanouts.
Hence, this warning message can be safely ignored.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
