Knowledge Base Article
Warning: On-chip termination control block "name" parameter enable_parallel_termination changed to true
Description
You may see this warning when you compile a design using DDR3 SDRAM Controller with UniPhy in Quartus® II software version 11.1SP1 or earlier. This warning can safely be ignored since parallel termination is expected.
The warning is scheduled to be fixed in a future version of Quartus II software.
Updated 2 months ago
Version 2.0
