Knowledge Base Article
WARNING: ncvhdl_p: *W,UNXPCL white space assumed after apostrophe [13.5]
Description
The warning with PCIe® VHDL files generated by MegaWizard™ comes from the limitation of NCVHDL parser. So you can safely ignore the warning.
You can also suppress the warning by using " -CONTROLRelax SPLISC " option with ncvhdl command.
Updated 2 months ago
