Knowledge Base Article
Warning Message Displayed When Driving User Logic with Custom PLL in Hard Memory Interface
Description
This problem affects DDR2 and DDR3 products.
External memory interfaces targeting Arria V or Cyclone V devices and using the hard memory controller will generate warning messages if you drive user logic with a PLL other than the AFI clock.
The following warning messages are displayed (where SingleInterface_mem_if_ddr3_emif_0. is a user-specified name):
Critical Warning: SingleInterface_mem_if_ddr3_emif_0_p0_pin_map.tcl: Failed to find PLL clock for pins Warning: SingleInterface_mem_if_ddr3_emif_0_p0_pin_map.tcl: Could not find all DRIVER CORE CK pins
Resolution
The workaround for this issue is as follows:
  1. Open the pin-mapping script in a text editor.
  2. In the pin-mapping script, locate the following lines:
if {[get_collection_size [get_registers -nowarn (driver_core_ck_pins)]] > 0} { �
Replace the above lines with the following:
if {[string compare -nocase (driver_core_ck_pins) ""] != 0 && [get_collection_size [get_registers -nowarn (driver_core_ck_pins)]] > 0} {
  • In the SDC file, change the pll_driver_core_clock to the clock that drives the user logic.
  • This issue will be fixed in a future version.
Updated 1 month ago
Version 2.0
