Knowledge Base Article
Warning Message Displayed Twice
Description
If you change the Clock Rate units to mHz in the Parameter Setting dialog box a warning message is displayed. After closing the warning message, if you then click on both the Clock Rate and the Desired Output Frequency boxes, two separate warning messages with the same content are displayed.
All configurations.
Resolution
Close both of the warning messages.
This issue will be fixed in a future version of the NCO MegaCore function.
Updated 1 month ago
