Knowledge Base Article
warning LNK4088: image being generated due to /FORCE option; image may not run
Description
Due to a problem in the Intel® Quartus® Prime Standard and Pro Edition software for version 18.0 and earlier for Windows*, you may see the following warning message when you compile your design using Intel HLS compiler.
Resolution
It is safe to ignore this warning because the executable is expected to work correctly. This issue is documented in Intel® High Level Synthesis Compiler Release Notes.
Updated 1 month ago
