Knowledge Base Article
Warning: Ignored filter at instance_name_p0.sdc(675): {instance_name_clkout[0]} {instance_name_clkout[1]} could not be matched with a clock
Description
When running TimeQuest on a DDR3 UniPHY design in the Quartus®  II software version 11.0, you may get the following warning:
Resolution
The workaround for this issue is to modify the instance_name_pin_map.tcl file. Here are the steps to modify the tcl file:
  • open the instance_name_pin_map.tcl file in an editor
  • locate the instance_name_p0_get_all_instances_dqs_pins function in the tcl file
  • Change the following line from :
lappend dqs_pins (ck_pins)
To :
foreach { ck_pin } (ck_pins) {
lappend dqs_pins
  • Re-compile the design
This issue will be fixed in a future version of the Quartus II software.
Updated 2 months ago
Version 2.0
