Knowledge Base Article
Warning: "CONV_INTEGER: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, and it has been converted to 0!" (ModelSim, VHDL Output File (.vho))
Description
You may get this warning message when simulating your Quartus™ or MAX PLUS® II VHO file in ModelSim. These warning messages do not have any effect on your simulation results, and should be ignored.You can suppress these warning messages by doing the following in ModelSim:
- Open the Simulation dialog box (Options menu).
- Set the option Suppress Warnings from Synopsys Packages to On.
- Click OK.
Related Articles
Updated 1 month ago
Version 3.0No CommentsBe the first to comment
