Knowledge Base Article
Warning: Can't generate programming files for project because design file "cpu_0.vhd" is encrypted. It does not have license file support that allows generation of programming files.
Description
This warning message occurs in the Quartus® II software when you use the bottom-up incremental compilation flow to compile a project that includes an imported lower-level Nios® II design partition or other encrypted Intellectual Property (IP). The Quartus II software does not generate programming files if you compile a design with an imported design partion that includes an encrypted design (such as the Nios II processor).
For instructions to work around this issue, refer to the Quartus II Incremental Compilation for Hierarchical & Team-Based Design (PDF) chapter in volume 1 of the Quartus II Handbook.
Updated 1 month ago
Version 2.0
