Knowledge Base Article
Warning: Can't find Memory Initialization File or Hexadecimal (Intel-Format) File name.mif -- setting all initial values to 0
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software versions 23.1 and earlier, you might see this warning when using the MIF file to initialize RAM in the VQM file.
Resolution
This problem is fixed beginning with the Intel® Quartus® Prime Pro Edition Software version 23.2
Updated 1 month ago
Version 2.0
