Knowledge Base Article
Warning: Address port 3 on DualMem block 'DualMem' is smaller than required to access all addresses and will be zero-padded to <number> bits.
Description
Due to a problem in DSP Builder for Intel® FPGAs, you may see this warning when simulating a design that includes a DualMem block.
The full warning is
Warning: Address port 3 on DualMem block 'DualMem' is smaller than required to access all addresses and will be zero-padded to bits. You cannot access all addresses from this port. SUGGESTION: Change the data type of the source block.
Resolution
The warning for Address port 3 is incorrect and safe to ignore.
This problem is fixed beginning with version 20.1 of DSP Builder for Intel® FPGAs.
Updated 2 months ago
Version 2.0
