Knowledge Base Article
Warning (332174): Ignored filter at alt_xcvr_reconfig.sdc: *xcvr_native*avmm*pmatestbussel[0] could not be matched with a clock
Description
Due to a problem in the Quartus® II software version 13.0 and later, the automatically-generated timing constraints for the 10GBASE-R IP in the file alt_xcvr_reconfig.sdc are incorrect. You may encounter the above warning in the TimeQuest timing analyzer.
The reason for the warning is that the hierarchical name for the pmatestbussel[0] signal within the 10GBASE-R IP does not match the name specified in the alt_xcvr_reconfig.sdc file.
Resolution
To work around this problem, edit the alt_xcvr_reconfig.sdc file and modify the following assignment to match the 10GBASE-R IP hierarchical naming structure:
From:set_clock_groups -asynchronous -group [get_clocks {*xcvr_native*avmm*pmatestbussel[0]}]
To:set_clock_groups -asynchronous -group [get_clocks {*xcvr_10gbaser_native*avmm*pmatestbussel[0]}]
This problem is scheduled to be fixed in a future release of the Quartus II software.
Updated 2 months ago
