Knowledge Base Article
Warning (332088): No paths exist between clock target "*|altpcie_a10_hip_pipen1b|wys|core_clk_out" of clock "dut|wys~CORE_CLK_OUT" and its clock source. Assuming zero source clock latency.
Description
Due to a problem in the the Intel® Quartus® Prime Software versions 16.1 and earlier, you might see this warning when compiling designs containing the Intel® Arria® 10 Hard IP for PCI Express.
Resolution
This warning can be safely ignored.
The warning is scheduled to be removed from future releases of the Intel Arria 10 Hard IP for PCI Express.
Updated 2 months ago
