Knowledge Base Article
Warning (332060): Node: :csr_controller|csr_control_data_reg[0] was determined to be a clock but was found without an associated clock assignment.
Description
Due to a problem in the Quartus® Prime Pro and Standard Edition Software version 18.1 and earlier, you may see the register csr_control_data_reg [0] in the Serial Flash Controller II Intel® FPGA IP is reported as an unconstrainted clock.
Resolution
This warning can be safely ignored, csr_control_data_reg [0] is not a clock.
Related Articles
Warning (332060): Node: <Path>|csr_control_data_reg[0] was determined to be a clock but was found without an associated clock assignment.
Updated 2 months ago
Version 2.0
