Knowledge Base Article
Warning (332060): Node: <node> was determined to be a clock but was found without an associated clock assignment.
Description
You may get this warning message in the Quartus® II software for signals that drive the clock input of a register or the enable input of a latch if you have not created a clock constraint for this signal.
Resolution
To avoid this warning, either change your logic so this signal does not drive one of these or inputs or properly constrain the signal.
Updated 3 months ago
Version 2.0
