Knowledge Base Article
Warning (272007): Errors encountered during regeneration of clearbox design file <file name>_altera_asmi_parallel_core_altera_asmi_parallel_core.v for device_family MAX 10, the original design may not work correctly.
Description
Due to a problem in the Quartus® Prime Standard edition software, you may see this warning when compiling a design that contains the Altera Generic QUAD SPI controller. This warning occurs in designs targeting MAX® 10 devices.
Resolution
It is safe to ignore this warning for MAX 10 designs.
Updated 23 days ago
Version 2.0
