Knowledge Base Article
Warning (21610): Output port "<port>" in instance "<inst>" of entity "<entity>" does not have a driver. Connecting to the default value "gnd".
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.3, you might see this warning despite suppressing the message in your project.
The MESSAGE_DISABLE assignment does not work for suppressing warning 21610.
Resolution
To work around this problem, use the following assignment to suppress this warning:
set_instance_assignment -name UNCONNECTED_OUTPUT_PORT_MESSAGE_LEVEL OFF -to “<inst|port>”
This problem is fixed beginning with the Quartus® Prime Pro Edition Software version 24.3
Updated 2 months ago
Version 3.0No CommentsBe the first to comment
