Knowledge Base Article
Warning (16295): Ignoring virtual IO assignment for "<signal name>"
Description
The Intel® Quartus® Prime Pro edition software generates this warning during compilation when a virtual pin assigment is made to a module output that is also defined as open drain with the OPNDRN primitive. This cause the Intel® Quartus® Prime Pro edition software to ignore the virtual pin assignment.
Resolution
To avoid this warning, do not use virtual pin assignments on open drain outputs that uses the OPNDRN primitive.
Updated 2 months ago
Version 2.0
