Knowledge Base Article
Warning (12914):The file,<file name>.sopcinfo, is not embedded into sof file as expected.
Description
Due to a problem in the Quartus® Prime software version 15.1, you may see this warning during compilation.
This warning doesn\'t not affect the circuit behavior. It only affects the System Console tool.
Resolution
You can ignore this warning safely if you don\'t use System Console.
This problem is scheduled to be fixed in a future version of the Quartus Prime software.
Updated 3 months ago
