Knowledge Base Article
Warning (12283): Assignment INPUT_TERMINATION on transceiver refclk clk buf/pin is not supported
Description
In Arria® V, Cyclone® V and Stratix® V devices the INPUT_TERMINATION assignment cannot be used on transceiver pins.
Resolution
Change the INPUT_TERMINATION of pin <pcie_refclk_name> to \'Transceiver Dedicated Refclk Pin Termination\' and select the appropriate Quartus® Settings File(QSF) assignments.
Refer to the Altera Transceiver PHY IP Core User Guide for more information on how to use these assignments.
As an example, the .qsf file will appears as below if the option DC_COUPLING_INTERNAL_100_OHM is used:
set_instance_assignment -name XCVR_REFCLK_PIN_TERMINATION DC_COUPLING_EXTERNAL_100_OHMS -to <pcie_refclk_name>
Related Articles
Updated 2 months ago
Version 2.0
