Knowledge Base Article
Warning (10240): Verilog HDL Always Construct warning at altpciexpav_stif_txresp_cntrl.v
Description
Due to a problem in the Intel® Arria® 10 Hard IP for PCI Express*, you will see the following warnings during analysis and elaboration when using the Intel® Quartus® II or Intel® Quartus® Prime Standard software.
Warning (10240): Verilog HDL Always Construct warning at altpciexpav128_txresp_cntrl.v(344): inferring latch(es) for variable "payload_limit_cntr", which holds its previous value in one or more paths through the always construct
Info (10041): Inferred latch for "payload_limit_cntr[0]" at altpciexpav128_txresp_cntrl.v(344)
Info (10041): Inferred latch for "payload_limit_cntr[1]" at altpciexpav128_txresp_cntrl.v(344)
Info (10041): Inferred latch for "payload_limit_cntr[2]" at altpciexpav128_txresp_cntrl.v(344)
Info (10041): Inferred latch for "payload_limit_cntr[3]" at altpciexpav128_txresp_cntrl.v(344)
Resolution
These warning can be safely ignored, and have been fixed in Intel® Quartus® Prime Pro software starting in version 16.1.
Updated 2 months ago
Version 2.0
