Knowledge Base Article
Warning (10230): Verilog HDL assignment warning at *instance_name*_write_datapath.v(118): truncated value with size to match size of target (1)
Description
You may experience the above warning when compiling the DDR2 or DDR3 SDRAM Controller with UniPHY IP in Quartus II.
This warning occurs as Quartus II synthesized away some of registers and logics that connected to the 'phy_ddio_oct_ena_pre_shift' signal due to undeclared bus for this signal in <instance name and hierarchy>_write_datapath.v file. This lead to incorrect OCT switching behavior.
Resolution
Declare the \'phy_ddio_oct_ena_pre_shift\' signal as below in the generated <instance name>_write_datapath.v file before their assignment.
wire [AFI_DQS_WIDTH-1:0] phy_ddio_oct_ena_pre_shift;
Updated 3 months ago
