Knowledge Base Article
Warning : pcie_link_inspector and JTAG master not found
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 22.2 and onward, the following error will occur when performing the PCI Express Link Inspector Debugging tool in L-Tile and H-Tile Avalon® Memory-mapped FPGA IP for PCI Express for Stratix® 10 GX FPGA.
Warning: pcie_link_inspector and JTAG master not found
error: master_read_32 : Error: The given path is not valid
      while executing
"master_read_32 $slave [expr $base_addr - {$address_hex*4}] 1"
     (procedure ."pli_read32" line 2)
     invoked from within
"pli_read32 $pli_adne $ltssm_base_addr 0x01"
    (procedure "ltssm_debug_check" line 2)
    invoked from within
"ltssm_debug_check"
   (file "TCL/link_insp_test_suite.tcl" line 176)
   invoked from within
"source TCL/link_insp_test_suite.tcl"
   (file "c:/temporary/tcl/pcie_link_inspector.tcl" line 26)
   invoked from within
"source $PATH/pcie_link_inspector.tcl"
Resolution
To work around this problem, copy the TCL folder and .sof file from the L-tile and H-tile Avalon® Memory-mapped FPGA IP for PCI Express example to the project directory, then read it as designed.
Reboot the system for enumeration. Run the commands below
    $ source TCL/setup_adme.tcl
    $ source TCL/xcvr_pll_test_suite.tcl
    $ source TCL/ltssm_state_monitor.tcl
    $ source TCL/link_insp_test_suite.tcl
    $ source TCL/hip_reconfig_display.tcl
    $ ltssm_display 25
This problem is fixed in Quartus® Prime Pro Edition Software v22.2 during example design generation.
Updated 20 days ago
Version 2.0
