Knowledge Base Article
Warning : Input frequency violation on DLL instance
Description
When running simulations with the ModelSim*-Intel FPGA Edition software on the UniPHY DDR3 IP with either the example testbench or the <IP _name>_sim fileset,  the simulation may generate transcript messages of type :
Note: Input frequency on DLL instance <IP_name>_example_sim.e0.if0.dll0.dll_wys_m.inst now matches with specified clock frequency.
Warning : Input frequency violation on DLL instance <IP_name>_example_sim.e0.if0.dll0.dll_wys_m.inst. Specified input period is 2500 ps but actual is 3750 ps
and the simulation never completes calibration.
This may occur with some combinations of DDR3 UniPHY parameter editor -> PHY Settings parameters for "Memory clock Frequency" and "PLL reference clock frequency".
It is due to a rounding issue in the UniPHY DDR3 IP testbench clock source code.
Resolution
The workaround for the design example testbench is as follows :
Verilog:
In the file <IP_name>_example_sim.v,  for the pll_ref_clk instance of altera_avalon_clock_source, on code line
CLOCK_RATE (x)  where x is a frequency value change x to be the frequency specified as the DDR3 megawizard PHY Settings ->  “PLL reference clock frequency”
VHDL:
  1. In the file submodules/altera_avalon_clock_source.vhd, change the line:
    generic (CLOCK_RATE : integer :=10);  -- default rate 10 MHz (100 ns)
    to:
    generic (CLOCK_RATE : real :=10.0);  -- default rate 10 MHz (100 ns)
  1.  In the file <IP_name>_example.vhd, change:
    component altera_avalon_clock_source is
        generic (
            CLOCK_RATE : positive := 10
        port (
            clk : out std_logic  -- clk
    end component altera_avalon_clock_source;
to:
        generic (
            CLOCK_RATE : real := 10.0
        port (
  1. In the file <IP_name>_example.vhd, change the input frequency x to the value specified in the DDR3 parameter editor PHY settings ->  “PLL reference clock frequency”. For example, if the input frequency is 100 MHz, put 100 for the value of x.
Change
pll_ref_clk : component altera_avalon_clock_source
        generic map (
            CLOCK_RATE => x
        port map (
            clk => pll_ref_clk_clk_clk  -- clk.clk
to:
        generic map (
            CLOCK_RATE => “PLL reference clock frequency”
        port map (
This problem is fixed starting with the Quartus® II software version 12.0.
Updated 2 months ago
Version 2.0
