Knowledge Base Article
Visual Basic Error 53: File not found: <file name>.dll
Description
You may see this error when opening the Early PowerPlay Power Estimator (EPE) tool.
When you run the EPE for the first time, the dll files are copied to a temporary file folder on your PC.  When a dll file is missing, this error is generated.
Resolution
To fix this issue, follow the instructions below:
  1. Close all the EPE windows and/or Excel spreadsheets, including those for other projects
  2. Confirm the name of the dll file name shown in the error message window
  3. Go to \User\<your user folder>\AppData\Local\Temp
  4. You should see a dllc file which has the same name of the dll file shown in the error message.
    For example, if the error message shows epe_14_0_28nm_B22_hid_32bit.dll, you should see epe_14_0_28nm_B22_hid_32bit.dllc in the folder.
  5. Delete the above dllc file
  6. Open the EPE
After opening the EPE, you should see both <file name>.dll and <file name>.dllc in the above temporary folder.
This behavior is not scheduled to be fixed in a future Quartus® software release.
Updated 1 month ago
Version 2.0
