Knowledge Base Article
Video and Image Processing Suite Fails to Launch in Windows
Description
Some IP cores in the Video and Image Processing Suite version 11.0 fail to launch in Windows if the installation path for the Windows-platform ACDS contains spaces.
This issue affects all the following Video and Image Processing cores installed in Windows platform with spaces in the installation path:
  • 2D FIR Filter IP core
  • 2D Median Filter IP core
  • Chroma Resampler IP core
  • Clipper IP core
  • Color Plan Sequencer IP core
  • Color Space Converter (CSC) IP core
  • Clipper IP core
  • Deinterlacer IP core
  • Frame Buffer IP core
  • Gamma Corrector IP core
  • Interlacer IP core
  • Scaler IP core
  • Test Pattern Generator IP core
You cannot access the Video and Image Processing Suite parameters through the MegaWizard Plug-In Manager.
Resolution
Install the ACDS Suite in a directory that does not contain spaces in its path.
This issue will be fixed in a future version of the Video and Image Processing Suite.
Updated 2 months ago
Version 2.0
