Knowledge Base Article
VHDL use clause error when compiling your design
Description
The issue is triggered when a user try to configure some IP which results in different port lists. In that case, Qsys Pro generates VHDL wrapper files under the same system generation directory.
For example, if add two reset_bridge to a Qsys Pro system from the IP catalog, and configure one to use reset request signal, and the other without using reset request signal. When you choose “generate VHDL” for either synthesis or simulation. You can find that there are two files generated under system generation directory. When you try to compile it, you get the following error: VHDL use clause error at xxx: VHDL design library does not contain primary unit xxx.
Resolution
Generate Verilog instead of VHDL.
Updated 3 months ago
Version 2.0
