Knowledge Base Article
VHDL IP Functional Simulation Fails
Description
When running the demonstration testbench with VHDL simulations, you receive the following error:
Signal "wire_gnd" is type ieee.std_logic_1164.std_logic; expecting type ieee.std_logic_1164.std_logic_vector.
This issue affects Stratix V receiver variants.
There is no design impact.
Resolution
Use Verilog HDL simulations.
This issue will be fixed in a future version of the POS-PHY Level 4 MegaCore function.
Updated 11 months ago
Version 3.0
