Knowledge Base Article
VHDL Example Driver Fails in Simulation
Description
The VHDL example driver for designs using the high-performance controller (HPC I) fails to simulate.
This issue affects all ALTMEMPHY-based designs using the high-performance controller (pre-11.0), and targeting VHDL.
The VHDL example driver fails to compile in VCS/VCSMX and hence cannot simulate.
Resolution
The workaround for this issue is to use the Verilog example driver.
This issue will not be fixed.
Updated 1 month ago
