Knowledge Base Article
Verilog HDL Simulation Fails
Description
Running a simulation with the Verilog HDL testbench results in an empty summary_output.txt file.
This issue affects all Verilog HDL configurations.
You cannot use the summary_output.txt file to evaluate the functionality of the design. But you can evaluate the functionality by looking at the simulation waveform.
Resolution
Run the simulation with a VHDL design and use the VHDL testbench.
This issue will be fixed in a future release of the Reed-Solomon Compiler.
Updated 2 months ago
