Knowledge Base Article
Verilog HDL error at template_file_name.v(46): zero or negative value for size
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition software version 23.2. You will see the error message seen below when using the M18x19_systolic with Preadder and Coefficient Verilog HDL. Language template.
Verilog HDL error at <template file name>.v(46): zero or negative value for size
Resolution
To work around this problem in the Intel® Quartus® Prime Pro Edition Software version 23.2, follow the steps below:
Modify the RTL in the Intel® Quartus® Prime Pro Language template  - DSP Features for 20-nm Device - M18x19_systolic with Preadder and Coefficient:
reg signed [COEF_WIDTH-1:0] c4_coef [0];
To:
reg signed [COEF_WIDTH-1:0] c4_coef[0:0];
Or:
reg signed [COEF_WIDTH-1:0] c4_coef;
This problem has been fixed starting in the Intel® Quartus® Prime Pro Edition Software version 23.3.
Updated 1 month ago
Version 2.0
