Knowledge Base Article
VCS-MX Simulation with Simulation Script vcsmx_setup.sh Fails at 0ns
Description
A VCS-MX simulation of a UniPHY-based external memory interface IP core in VHDL with the provided simulation script vcsmx_setup.sh fails at time 0ns with the following error:
0 ns: ERROR: altera_mem_if_sequencer_cpu_no_ifdef_params_sim_cpu_inst_test_bench/F_valid is 'x'. at time 0 Scope: \DUT_EXAMPLE_SIM.E0.IF0.S0.CPU_INST .the_altera_mem_if_sequencer_cpu_no_ifdef_params_sim_cpu_inst_test_bench File: ./../..//submodules/altera_mem_if_sequencer_cpu_no_ifdef_params_sim_cpu_inst_test_bench.v Line: 498.
This issue affects DDR2 and DDR3 protocols, and QDR II/II and RLDRAM II when using the Nios II-based sequencer.
Resolution
The workaround for this issue is as follows:
  1. In a text editor, open one of the following files, whichever applies:
  • <variant_name>_example_design/simulation/vhdl/submodules/dut_example_sim_e0_if0_s0_rst_controller.vho
  • <variant_name>_sim/submodules/dut_e0_if0_s0_rst_controller.vho
  1. Change the initial value of the registers in the reset synchronizer from:
SIGNAL dut_example_sim_e0_if0_s0_rst_controller_altera_reset_controller_rst_controller_altera_reset_synchronizer_alt_rst_sync_uq1_altera_reset_synchronizer_int_chain_0_46q : STD_LOGIC := \'0\';� SIGNAL dut_example_sim_e0_if0_s0_rst_controller_altera_reset_controller_rst_controller_altera_reset_synchronizer_alt_rst_sync_uq1_altera_reset_synchronizer_int_chain_1_45q : STD_LOGIC := \'0\';� SIGNAL dut_example_sim_e0_if0_s0_rst_controller_altera_reset_controller_rst_controller_altera_reset_synchronizer_alt_rst_sync_uq1_altera_reset_synchronizer_int_chain_out_47q : STD_LOGIC := \'0\';
to:
SIGNAL dut_example_sim_e0_if0_s0_rst_controller_altera_reset_controller_rst_controller_altera_reset_synchronizer_alt_rst_sync_uq1_altera_reset_synchronizer_int_chain_0_46q : STD_LOGIC := \'1\';� SIGNAL dut_example_sim_e0_if0_s0_rst_controller_altera_reset_controller_rst_controller_altera_reset_synchronizer_alt_rst_sync_uq1_altera_reset_synchronizer_int_chain_1_45q : STD_LOGIC := \'1\';� SIGNAL dut_example_sim_e0_if0_s0_rst_controller_altera_reset_controller_rst_controller_altera_reset_synchronizer_alt_rst_sync_uq1_altera_reset_synchronizer_int_chain_out_47q : STD_LOGIC := \'1\';
(The exact names of your signals may differ from those above, but they will contain the substring altera_reset_synchronizer_int_chain .)
Updated 1 month ago
Version 2.0
