Knowledge Base Article
(vcom-1133) Type mismatch found on port
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software, if you generate an IP megacore with VHDL selected, you may encounter these errors when compiling for simulation:
# ** Error: .<your module>.vhd<your line number>: (vcom-1133) Type mismatch found on port <your port>".
#    In the component "<your component>", the port type is "ieee.std_logic_1164.STD_LOGIC".
#    In the entity "<your lower level entity>", the port type is "ieee.std_logic_1164.STD_LOGIC_VECTOR"
Resolution
To work around this issue you must edit the generated RTL and match the data types in both the top instance and the testbench.
For example, for a module called "FP_TEST", you would do the following:
Make the following changes in <your tb>_tb.vhd
architecture rtl of FP_TEST_tb is
                component FP_TEST is
                                port (
                                                a      : in  std_logic_vector(63 downto 0) := (others => 'X'); -- a
                                                areset : in  std_logic                     := 'X';             -- reset
                                                b      : in  std_logic_vector(63 downto 0) := (others => 'X'); -- b
                                                clk    : in  std_logic                     := 'X';             -- clk
                                                opSel  : in  std_logic                     := 'X';             -- opSel
                                                q      : out std_logic_vector(63 downto 0)                     -- q
                end component FP_TEST;
                fp_test_inst : component FP_TEST
                                port map (
                                                a      => fp_test_inst_a_bfm_conduit_a,            --      a.a
                                                areset => fp_test_inst_areset_bfm_reset_reset,     -- areset.reset
                                                b      => fp_test_inst_b_bfm_conduit_b,            --      b.b
                                                clk    => fp_test_inst_clk_bfm_clk_clk,            --    clk.clk
                                                opSel  => fp_test_inst_opsel_bfm_conduit_opsel(0), --  opSel.opSel
                                                q      => fp_test_inst_q_q                         --      q.q
To:
                                port (
                                                opSel  : in  std_logic_vector(0 downto 0)  := (others => 'X'); -- opSel
                                port map (
                                                opSel  => fp_test_inst_opsel_bfm_conduit_opsel, --  opSel.opSel
And make the following changes in <your module>.vhd
entity FP_TEST is
                port (
                                a      : in  std_logic_vector(63 downto 0) := (others => '0'); --      a.a
                                areset : in  std_logic                     := '0';             -- areset.reset
                                b      : in  std_logic_vector(63 downto 0) := (others => '0'); --      b.b
                                clk    : in  std_logic                     := '0';             --    clk.clk
                                opSel  : in  std_logic                     := '0';             --  opSel.opSel
                                q      : out std_logic_vector(63 downto 0)                     --      q.q
end entity FP_TEST;
architecture rtl of FP_TEST is
                component FP_TEST_altera_fp_functions_160_xhvb5va is
                                port (
                                                q      : out std_logic_vector(63 downto 0);                    -- q
                                                opSel  : in  std_logic                     := 'X'              -- opSel
                end component FP_TEST_altera_fp_functions_160_xhvb5va;
To:
entity FP_TEST is
                port (
                                opSel  : in  std_logic_vector(0 downto 0)  := (others => '0'); --  opSel.opSel
end entity FP_TEST;
                                port (
                                                opSel  : in  std_logic_vector(0 downto 0)  := (others => 'X')  -- opSel
This is scheduled to be fixed in a future release of the Intel® Quartus® Prime Software.
Updated 1 month ago
Version 2.0
