Knowledge Base Article
Using BluePrint's Autoplace All feature to place the periphery generates assignments that might cause an internal error in quartus_syn
Description
If you invoke BluePrint\'s Autoplace All feature to place the periphery for the
following designs, BluePrint generates assignments that might cause an internal
error in Spectra-Q™ Synthesis (quartus_syn)
when they are added to the Quartus® Prime Settings File
(.qsf):
- Designs that have the SignalTap™ II Logic Analyzer Trigger in to pin feature or the Trigger out to pin feature, or both, enabled.
- Designs that contain the Arria® 10 Transceiver
Native PHY IP core with the
tx_analog_resetorrx_analog_resetsignal connected to the top-level inputs.
Resolution
If your designs satisfy the listed criteria, avoid using BluePrint\'s AutoPlace All
feature. Alternatively, remove the assignments that cause the internal error in
quartus_syn. These assignments have targets to hierarchy paths of
the form auto_fab_0|debug.export.*. For example:
set_location_assignment IOOBUF_X142_Y44_N18 -to auto_fab_0|debug.export.alt_sld_fab_0_splitter_receive_1[0]~output -tag "BluePrint Location Assignment"Updated 3 months ago
