Knowledge Base Article
URL Project Location Causes Project Creation Error
Description
When you try to create a new project in an existing workspace, you might see an error dialog box saying:
Project cannot be created. Reason: Internal Error
This error might occur if the path to any project in the workspace is a URL location, for example file:/F:/Design. To view the path, right-click on the project and select Properties.
Resolution
Import your existing application and system library projects to a new workspace.
Updated 3 months ago
