Knowledge Base Article
Update BFM instance names for some peripherals in HPS Qsys systems
Description
If you generate a hard processor system (HPS) IP in Qsys that contains a NAND Flash Controller, a queued serial peripheral interface (QSPI) Flash Controller or a serial peripheral interface (SPI) Controller, compilation of the Verilog simulation model generated by Qsys might fail.
Resolution
Update the following bus functional model (BFM) sub-component instantiation names in component <Qsys design name>_<HPS IP instance name>_fpga_interfaces:
- Change
nandtonand_inst - Change
qspi_sclk_outtoqspi_sclk_out_inst - Change
spim0_sclk_outtospim0_sclk_out_inst - Change
spim1_sclk_outtospim1_sclk_out_inst
Updated 2 months ago
