Knowledge Base Article
Unstable Designs with LVDS in Hardware
Description
You may get unstable results when running designs that contain LVDS transceiver blocks in hardware. This is caused by the constraints provided with the MegaCore function.
This issue affects all configurations that contain LVDS transceiver blocks.
Resolution
Edit the constraint file, <project directory>/variation name>_constraint.sdc., and replace lines 410 through 417 with the following lines:
set_clock_groups -asynchronous -group {altera_tse_mac_rx_clk_0} -group {altera_tse_mac_tx_clk_0} -group {altera_tse_rx_afull_clk} -group {altera_tse_sys_clk} -group {altera_tse_ref_clk \ altera_tse_multi_mac_pcs_pma_inst|the_altera_tse_pma_lvds_rx_0|altlvds_rx_component|auto_generated|rx[0]|clk0
\ altera_tse_multi_mac_pcs_pma_inst|the_altera_tse_pma_lvds_rx_0|altlvds_rx_component|auto_generated|pll|clk[0]}
This issue will be fixed in a future version of the Triple-Speed Ethernet MegaCore function.
