Knowledge Base Article
Unexplained Errors After Compilation in Nios II Software Build Tools for Eclipse
Description
After compiling a project with the Nios II Software Build
Tools for Eclipse, you might encounter a <function/symbol>
could not be resolved message, or unexpected error markers
in the Eclipse text editor, even though the compilation is successful.
Resolution
To prevent the messages and markers from appearing, turn off the Code Analysis (codan) feature in the C/C Development Toolkit, as follows:
- Select the project.
- On the Project menu, point to Properties, then C/C , and click Code Analysis.
- Turn off the unwanted warnings and errors and click Apply.
The Code Analysis dialog box shows the following problem categories:
- Potential Programming Problems
- Coding Style
- Syntax and Semantic Errors
- Security Vulnerabilities
Each category lists warnings and errors that you can turn on or off.
If the error markers persist, delete them from the Problems view.
Updated 2 months ago
