Knowledge Base Article
Under what conditions might the Deterministic Latency PHY fail to achieve rx_syncstatus when implementing the OBSAI protocol in Cyclone® V devices?
Description
When implementing the OBSAI protocol using the Deterministic Latency PHY in Cyclone® V devices, you may fail to achieve rx_syncstatus when IDLE, IDLE_ACK, and IDLE_REQ patterns are sent during the link-up process. You can achieve synchronization by retriggering rx_patternalign or asserting rx_digitalreset.
Resolution
This applies to the Deterministic Latency PHY with the following configuration.
  • Data Rate: 3.072 Gbps
  • PMA-PCS Data Width: 20-bits
Related Articles
Updated 2 months ago
Version 2.0
