Knowledge Base Article
Under what conditions might the Deterministic Latency PHY fail to achieve rx_syncstatus when implementing the OBSAI protocol in Arria® V GX/GT devices?
Description
When implementing the OBSAI protocol using the Deterministic Latency PHY in Arria® V GX/GT devices, you may fail to achieve rx_syncstatus when IDLE, IDLE_ACK, and IDLE_REQ patterns are sent during the link-up process.
Resolution
You can achieve synchronization by retriggering rx_patternalign or asserting rx_digitalreset.
This applies to the Deterministic Latency PHY with the following configuration.
- Data Rate: 6.144 Gbps
- PMA-PCS Data Width: 20-bits
Related Articles
- Under what conditions might the Deterministic Latency PHY fail to achieve rx_syncstatus when implementing the OBSAI protocol in Arria® V GZ and Stratix® V devices?
- Under what conditions might the Deterministic Latency PHY fail to achieve rx_syncstatus when implementing the OBSAI protocol in Cyclone® V devices?
Updated 1 month ago
