Knowledge Base Article
Unable to Run FIR Compiler II
Description
The FIR Compiler II MegaCore fails to run with the following error message:
Error: couldn’t execute”<Quartus installation path>\quartus\common\ip\altera\windows32\fir_ip_api_interface”:
no such file or directory.
Resolution
To avoid this problem, follow these steps:
- Download the appropriate version of Microsoft Visual C 2008 SP1 Redistributable Package - (×86) for a 32-bit machine or (×64) for 64-bit Windows XP.
- Double-click on the vcredisk_x86.exe or vcredisk_x64.exe file you downloaded.
- Follow the instructions.
If you are prompted to uninstall or repair, click Repair.
Updated 2 months ago
