Knowledge Base Article
Unable to Configure DSP Resource Optimization Check Box in FFT Parameter Editor for Stratix V Devices
Description
In QDR II and QDR II SRAM Controllers with UniPHY targeting Arria V or Cyclone V devices, with read latency not equal to 2, the complimentary clock mem_cq_n is not used for capture, therefore the pin is unused.
In cases where read latency equals 2, mem_cq_n serves as the capture clock and mem_cq is unused.
This issue affects QDR II and QDR II SRAM Controllers targeting Arria V and Cyclone V devices, where read latency does not equal 2.
Resolution
You can manually enable this option by modifying the generated variation file manually, from DSP ARCH g => 0, to DSP ARCH g => 1.
Solution Status
This issue will be fixed in a future release of the FFT MegaCore function.
Updated 10 months ago
Version 2.0
