Knowledge Base Article
Timing Violation On *mr_oversample* Path in Arria V HDMI 2.0 Design Example
Description
When you run the HDMI design files for Arria V devices (av_sk_hdmi2) in the ACDS version 15.0, you will encounter timing violation issues on the *mr_rx_oversample:RX_OVERSAMPLE* path.
Resolution
There is no workaround for this issue.
This issue is fixed in version 15.0 Update 1 of the HDMI IP core.
Updated 17 days ago
Version 2.0
