Knowledge Base Article
Timing Violation In Half-Rate Bridge Enabled Designs
Description
Timing violation occurs during TimeQuest timing analysis for designs that use the high-performance controller II architecture with the Enable Half Rate Bridge option turned on.
This issue affects all designs that use the high-performance II controller architecture with the Enable Half Rate Bridge option turned on.
Timing violation occurs during compilation in the TimeQuest timing analyzer.
Resolution
Open the altera_avalon_half_rate_bridge_constraints.sdc file
in your project directory, and edit the slow_clock variable
and add derive_pll_clocks.
- Full-rate design
derive_pll_clocks
set slow_clk "*|altpll_component|auto_generated|pll1|clk[1]"
- Half-rate design
derive_pll_clocks
set slow_clk "*|altpll_component|auto_generated|pll1|clk[0]"
This issue will be fixed in a future version of the DDR and DDR2 SDRAM Controllers with ALTMEMPHY IP
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
