Knowledge Base Article
Timing Violation for Clocked Video Output in HDMI Arria V Design Example
Description
When you run the HDMI Arria V design example (av_sk) , you may encounter timing violation on the clocked video output path.
Resolution
There is no workaround for this issue.
This issue will be fixed in a future version of the HDMI IP core.
Updated 18 days ago
