Knowledge Base Article
Timing Violation for Arria 10 HDMI Design
Description
When you run the HDMI design for Arria 10 devices, the design may encounter timing violation within the dual-clock FIFO (DCFIFO) block. The DCFIFO block bypasses the HDMI video, audio, and auxiliary data from the receiver to the transmitter.
The timing violation only occurs when you run the design in the Quartus Prime Pro Edition version 15.1.
Resolution
There is no workaround for this issue.
This issue will be fixed in a future version of the HDMI IP core.
Updated 17 days ago
