Knowledge Base Article
Timing setup violations in SerialLite III Streaming IP Core Design Example
Description
The SerialLite III Streaming IP Core design example will run into timing setup violations in ACDS Quartus II version 15.0 due to the removal of false path in the seriallite_iii_streaming_demo.sdc file.
Resolution
Manually update the seriallite_iii_streaming_demo.sdc with the following constraint:
set_false_path -to [get_cells -compatibility *demo_mgmt*dp_sync_stage_1|o[*]]
Updated 1 month ago
Version 2.0
